Old 02-17-2013, 05:53 AM
Mooch's Avatar
Mooch Mooch is offline
Cobra Make, Engine: ERA 427 - #783
I just had this done to my garage, with a conversion to a Liftmaster Jackshaft opener. I have about 57-63 inches of clearance underneath depending on which stop the lift is set on, with the ceiling height being 122". The max clearance I have on the door is 115", so 7" from the ceiling, and I have hurricane beams on the door. The previous clearance was around 95", so I gained about 20". The opener conversion/door lift cost about $800.
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
