Old 02-17-2013, 11:45 AM
AL427SBF AL427SBF is offline
Yes, you've figured that out.
Since you now define road course use, build for HP. You only leave from rest once there. If you build 600+HP, you'll have more than abundant torque to get off corners provided you can put that power down.
Cobras= 90" WB, IRS and poor aerodynamics; not good for high torque applications.
Sort of gets back to the original proposition, maybe were talking past each other. Don't need to build for 600+ HP, need to build for the broadest torque curve the motor will support, HP will fall in-place as a derived result.
Actually, anytime I want to accelerate I will be calling on torque, all gears over a broad RPM range. Ohm's law analogy ...
V=RI
Torque = Current (I)
HP = Volts (V)
Motor Efficiency = Resistance (R)
High Voltage without Current, will power nothing
High Resistance without Current, will power nothing
High Current, regardless of Voltage or Resistance, will kill your ass
