Old 02-20-2013, 06:39 AM
427 Street's Avatar
427 Street 427 Street is offline
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
It's interesting that they appear to have the same approach to tail pipes that you used on your ERA - under the axle. I wonder why they didn't follow the factory route through the wheel wells - unless the SC wheels and wider tires interferred.
Dan, That's a good point about the tire and wheel size. I had no choice because of the upgraded ERA rearend's brake placement. The Jag rearend allows you to go up and over. I thought the same thing when I saw the exhaust on 3104. The clearance is low, but you get used to it once you drive it awhile. At first, I kept forgetting how little clearance there was, but it then becomes second nature. Legendary MC had a 289 car...forgot the chassis number...but it was also blue and it looked like the pea shooter pipes were actually an inch or two from touching!
"Some things get meaner as they get older."
