Old 02-20-2013, 09:47 AM
dallas_'s Avatar
dallas_ dallas_ is offline
Originally Posted by zrayr View Post
The difference, if any, will be negligible unless there is a mechanical flaw in the engine causing the adjacent cylinders to draw differently.
so for all practical purposes, just measuring the middle four venturies is sufficient. And that's the method prescribed by Jim Inglese as well.
Agreed.
You should not have to place the synchrometer on the 2 throats under your cowl.
Take a reading on the carb connected to the main linkage. The second throat on that carb is controlled by the throttle shaft so you don't need to adjust that one.
Adjust the adjacent carb via the attached throttle lever to match. The back throat (the one under the cowl) will follow via the throttle shaft so you should not have to adjust the air flow on it.
Follow the linkage and adjust the 3rd carb, then the one attached to that one via the throttle lever.
You really only need to adjust the air flow on 4 throats as zrayr says.
If the attached throats don't match up you probably have a problem with the throttle shafts binding.
John
