  #21 (permalink)
Old 02-20-2013, 04:28 PM
DanEC's Avatar
DanEC DanEC is offline
My hunch that the Pass side parking light was getting power from the green wire appears to be wrong.
With ignition on, parking lights on, and signals off - I have 12 volts on both green and red contacts in the parking light socket on the Pass side. I can only pick up power on the green wire at connections 54/27 when the signal is switched on.
It kind of seems like the green wire at the Pass side turn signal is not the same green wire at the 54/27 and coming out of the steering column and at the split between rear and front circuits at connector 68. I guess tomorrow I will take my meter and see if I can get continuity on the green wire between 54 and the turn signal contact in the light housing.
