Old 02-21-2013, 09:10 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by emm427 View Post
Did all 5 set do the same thing or the set you liked the best?
I have seen one defective bulb back feed the rest. When the customer applied the brakes all his parking lights came on. He had installed LED tail/brake lights. replaced them everything worked correct. try only the rear or front first to eliminate the problem area or bad bulbs...
I had only bought one sample of each LED and tried them out. Then I purchased six of the one I liked best.
At this point I'm going to stick with the incandescent twin filament as everything is working just fine. At some time in the future when I have some spare time I may try to figure out the LED problem.
