Old 02-23-2013, 03:07 PM
DanEC's Avatar
DanEC DanEC is offline
I carefully adjusted the idle speed setting on both carbs today so at idle they are equally contributing. I backed both off until they were just starting to make contact with the throttle blade shaft arm and then opened them up equally. Also marked my balancer and was able to put in a couple more degrees of initial timing. This all helped quite a bit as it still has a pretty good rump rump idle but will run at 700 to 750 rpm now without too much drama.
