Old 02-25-2013, 04:56 AM
750hp's Avatar
750hp 750hp is offline
It's all good Peter!
Bill - if you're still following this thread, is it worth turning over the engine on a weekly/monthly basis with the Marvel oil in the cylinders, or is just a revolution or two enough when you first coat the cylinders?
With the rockers removed to take the pressure off the springs, as long as the rings don't seize in the bore I've often wondered if there is any value in rotating the engine regularly.
Craig
