Old 02-26-2013, 04:47 AM
Bonos's Avatar
Bonos Bonos is offline
Club Cobra Member
Cobra Make, Engine: 1967 E-M with 302 Ford
I did this change out about five years ago and the hard part was connecting side pipes to headers. i made a spool peice with a flange for the ford header on one side and then a flange on the other end for existing side pipes . you must do a mock up to ensure correct pipe length between flanges because the lengths will be different on each pipe.
the right side and left sde will not interchange so each side must be made seperarte.
this will take time so you may want to look at under car exhaust
bonos
