Old 02-28-2013, 03:42 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by Zedn View Post
Original plan was to install one of these inline fillers Moroso Radiator Hose Fillers 63745 - SummitRacing.com near the upper hose on water pump to allow it to fill without air getting trapped (or would it still be trapped in heads?). I was then going to just run the overflow to a recovery tank. Only problem is the steam pipe would be higher. Do you think it would work to just tap the steam pipe into the inline filler? Not sure if the air/steam would push through into the system or get stuck at the top of the pipe.
That'll probably work fine. All you really need that steam tube to do is burp the air out of the motor when you fill the system, Most motors never had them and you had to mess around filling and topping up the system to be sure you got all the air out.
Mike Murphy
Melbourne Australia
