Old 03-01-2013, 01:01 PM
undy's Avatar
undy undy is offline
Originally Posted by AL427SBF View Post
That's a pretty interesting comparison between the two dyno runs. Peak HP and Torque virtually the same and from 4000 to 6200 the curves lay on top of each other. Below 4K it's a different matter. I'm assuming you did a carb tweak or something to improve low end torque at the expense of some low end HP? Hard to tell with the color resolution of the actual graphs (order of the runs). If it were me, the Torque ramp starting at 2200 is where I would have left things - the tune I would be looking for.
Carb tweaks and linkage adjustments...
I running twin Quick Fuel 750s on a tunnel wedge. I also think the go-fast pedal got mashed at different RPMs and the vacuum secondaries took a moment to open all the way. The larger CFM carbs causes the secondaries to be a bit more sluggish than, say twin 600s.
Too many toys?? never!
