Thread: Changing Gears
Old 03-02-2013, 09:46 AM
bulletbrown bulletbrown is offline
Cobra Make, Engine: Shell Valley Cobra Kit -428 Fe Built by Clayton Racing Engines
Exclamation A 588 big block
If you have a GM GTO , which is the same as the new Camaro, I would up grade the unit to stand up to that much power. It is a wonder you have not blown it aready. It is not a strong unit to begin with . I sell Camaros and we have repair a number of this unit on stock Camaro,s . We sell Camaro to Nickey custom Camaro builders and then change half shafts ect. in the hopes they will hold up to the added power of the supercharges they install. If you put a low gear ratio and sticky tires you will blow it to pieces . There is venders that will sell you the badly need up grades.
