Thread: Changing Gears
Old 03-02-2013, 04:23 PM
STL Mark STL Mark is offline
Originally Posted by bulletbrown View Post
If you have a GM GTO , which is the same as the new Camaro, I would up grade the unit to stand up to that much power. It is a wonder you have not blown it aready. It is not a strong unit to begin with . I sell Camaros and we have repair a number of this unit on stock Camaro,s . We sell Camaro to Nickey custom Camaro builders and then change half shafts ect. in the hopes they will hold up to the added power of the supercharges they install. If you put a low gear ratio and sticky tires you will blow it to pieces . There is venders that will sell you the badly need up grades.
No worries. I run Goodyear Eagle GT IIs. Basically the tires don't stick. So, I'm never in danger of destroying the rear end or the axles. If I needed a rear end that would hold up to full-on drag passes, I would pull the whole mess out and re-build with a much more substantial system. But, I have managed an 11.3 pass on those street tires. As it is, the 3.46 is a good road racing platform for now. On the track, even with Hoosiers - the stock SPF (Dana/GTO/whatever) does fine.
