Old 03-04-2013, 06:19 AM
blykins blykins is offline
You probably won't be able to spin it by hand and pump it up. If you have a priming tool, prime the pump with a big healthy drill motor and get the oil flowing. It should oil the lifters up enough to see what's going on.
If that doesn't work, you may be able to do a surgical procedure and pull the lifter pair out through the head/intake. If you took the lifter apart, you may be able to see if something has it clogged up, or if there is an issue.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
