Thread: Changing Gears
  #43 (permalink)
Old 03-04-2013, 07:02 PM
SPF1061's Avatar
SPF1061 SPF1061 is offline
Cobra Make, Engine: Superformance Mk III / Windsor platform
Originally Posted by mpanten View Post
I keep my tires aired up and they do not suck. You clearly have no experience with the Mickey Thompson tires. They actually handle pretty good with air in them. Sorry your first gear is a waste but I assure you mine is not. Yes I can come off idle and from a slow roll in first, nail the gas and not spin. The front end feels like its about to come off the ground but it does not spin.
If you dont believe me your welcome to take it for a spin and I will show you the miracle that we call first gear.
I also have a miracle called first gear, but mine thrives on a 3.27 rear axle ratio. I absolutely do not disbelieve you, but I do find it completely contrary to my experience. I wonder what engine you are running? Is it possible that you are running a peaky motor? I have run the M/Ts on my car and can smoke them at will in low gear above 2000/2500 rpm with a fully engaged clutch. I am quite jealous of the incredible traction you are achieving and want some for myself!
