Old 03-04-2013, 08:07 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I have found that sometimes you have a 48 IDA Weber with different synchrometer readings on each of the two throats.
You can get that fixed by slightly twisting the throttle shaft such as to achieve perfect matching vacuum rates.
Nothing sounds better than a Cobra in a Tunnel !
