Old 03-05-2013, 07:36 AM
DanEC's Avatar
DanEC DanEC is offline
Dan-what was the fix for adjusting floats, sight plugs and bowls as we wrote about?
Chas - I haven't done anything further for right now since after getting the timing and the idle adjusted it seems to be running fine for the moment. I'll find out more when I can get it on the road for a test drive. Long term I have thought about getting a set of proper coded Holleys from one of the FE suppliers to replace these. If I don't do that then I will probably look into replacing the bowls.
I'm following your suggestion (at least sometimes) to get it together and don't sweat some of the small details for now that can be worked out later.
Dan
