Old 03-06-2013, 05:45 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have a brand new Painless wiring harness I will sell you for $100 and you can re-wire your whole car in about 6 hours. Everything is labled and it is a no brainer. No offense but you need to find some other Cobra owners in your area and have a work day. You can get almost every bit of the things on your list done on a Saturday with a couple buds and a case of Budweiser.
Example a good set of Accel 714 plugs $40 with MSD wires @ $70 and ONE HOUR of your time and you are in it for $110 or less. Relocating the fuel filter $10 and 30 mins. (and why do you want to relocate it, mine is in the trunk next to my fuel pump?) . I am sure your brake lines are metal up to the axels and then you HAVE to use some flex line to the calipers (rubber hose or braided AN 4 lines).
If you get into any problems you have some very good friends here that will gladly help.
Clois Harlan
"Let's roll"
"Be part of Something Good
