Old 03-06-2013, 08:08 AM
ZOERA-SC7XX's Avatar
ZOERA-SC7XX ZOERA-SC7XX is offline
Are you still having the problem with charging? I had a bad fuse behind the dash light (fused link) to ignition switch and it drove me crazy until I found the problem. As far as the headers are concerned, keep the primaries loose until the sidepipes are correctly fitted. I used four small plastic wire ties on each side to keep the primary pipes squarely together and fitted the sidepipes without much problem.
