Old 03-06-2013, 12:03 PM
lippy lippy is offline
Unfortunately, FE hydraulic roller lifters are done by about 6000. Plus there's only so much horsepower to be had by a naturally aspirated, Edelbrock headed, pump gas, hydraulic roller'd FE....(that was a mouth full)
As for all aluminum engines and setting lash, I start with a cold spec of about .010" under hot spec. Easy to check on the dyno and I can run through them in less than 10 minutes.
Would it matter if we used hydraulic + other (than Edelbrock) heads?
