Old 03-06-2013, 05:11 PM
Zedn's Avatar
Zedn Zedn is offline
From memory older Honda engines rotate "backward" compared to most other makes, so maybe look for an older model Civic Alternator to mount reversed?
Backwards? Do you use reverse gear to go forwards?
Im pretty sure that all will charge either way, but from the reading i have done there can be cooling issues with running them backwards as the fan is blowing the other way.
