03-10-2013, 12:19 PM
Originally Posted by Jerry Clayton
If you are going to make your choice by what a dyno tells you---you need to go prepared---haqve every style air cleaner/filter that you can and do a b a tests-----I have seen many times an 8 hp change just with a different base plate on the carb
Oh yeah, the speed shop I'm going to has a lot of that stuff including various spacers ... but check my logic on this -
Once on the chassis dyno, do a couple of mild pulls with no air cleaner, dial in carb based on Ox sensor data.
Do a full pull, maybe two (again no air cleaner) and see where it all lands.
If the HP & Torque are basically where I want them, I would consider this the "goal" to strive for. If not, stop right there - time to consider a carb change or porting.
If a go, then try various buttoned up carb configs to get as close to the goal as possible.
... makes sense?
