Old 03-13-2013, 03:20 PM
Turbonut48 Turbonut48 is offline
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default Gasket
Here s a trick for making the gasket.
Cut out a piece of gasketing a little bigger than you need. With a small hammer , or something you can lightly tap with, tap all around the edges and into the holes. Ball peen hammer works good.
Then you have your outline and position of all the holes, carefully cut out with razor knife and scissors.
The Nut
Enough is enough. Too much is just right ( C.S )
