Old 03-17-2013, 02:57 AM
mdross1's Avatar
mdross1 mdross1 is offline
Originally Posted by lippy View Post
The support engineer at Isky told me that with their EZ Roller lifters (bushings, not needle bearings) I need to check the lash from time to time but if that lash is not changing then the rollers don't need to be removed and inspected. He also mentioned that typical solid roller lifters need to be inspected and possibly rebuilt every 7,500-10,000 miles, but the Isky ones should last probably 3-5x that long if driven on the street. I suppose he could've given me incorrect information, but he seemed to be on top of things, and is an Isky support engineer (also mentioned he has these in his daily driver). Am I naive to believe him?
A friend has a set of these in a near 1200 hp 632" Chev been there 35K now with 1000+lb open spring pressure.My set of Isky EZ rollers are in a Donovan 427"sbc 660lbs open pressure on a 440 cam lobe.Should last forever the bushings are pressure lubed.
