Old 03-12-2002, 08:47 PM
CSX 4027's Avatar
CSX 4027 CSX 4027 is offline
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default tURK
tHE GAIN YOU MIGHT HAVE WITH TUNNELPORT MIGHT NOT BE WORTH IT IN THE POWERBWBAND. iF YOU COULD GO hIGH RISER AND COMPRESSION YOU MIGHT BE IN the RIGHT DIRECTION. i HOPE YOU ARE NOT PLANNING ON LEmans RODS. You need tho move into the new century. Here;s the program
Sideoiler,Chevized rods,crank etc. JE new flow pistons. Edelbrock aluminum heads to flow by a pro. 12:1 compression. You will rev to 6800 all day and make 580 to 600 depending on the build. I have lots of info on what works and what does not..TOIK
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
