Old 03-20-2013, 06:04 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Earl,
If you have someone to help you, why not try putting the door in like it would be when shut and have them hold it and see which hinge mounting will work out the best or if you are going to have to modify some holes. Also if the holes in the door just go through fiberglass I would think about putting some steel backing in there to prevent the bolts from wearing through after being used for a time. I think getting my doors mounted and aligned so the top was even with the body and everything was one of the worst parts of my build. But I had steel plates in the door for the hing bolts to go through and mine had a heavy steel hinge that bolted with 4 bolts to a welded in panel on the cowl bar.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
