  #23 (permalink)
Old 03-25-2013, 01:11 PM
lippy lippy is offline
The big brakes are fine for the street, Wilwood or Sierra. I use the soft Hawk pads -- they do fine for the street, and work better the warmer you get them. I don't have the "pop, click" noise, but they will squeal a bit when cold. If you want to see some nice pad graphs for temps, click here: Pad Friction Graphs
Thanks Patrick. The ERA guys sure are on top of things - especially for a small company. I checked out the graphs in the link. Am I interpreting this incorrectly, or does it look like Polymatrix A has a higher coefficient of friction across all temps (100-1300F), versus all of the others, and should be the better choice, unless the wear is significantly worse? But those pads are intended for racing only, and not street use.
