Old 03-26-2013, 11:59 AM
patrickt patrickt is offline
You can crank for pressure or pull the diz and spin the shaft.
Uh-huh... so now the quick and easy oil change requires turning on the compressor, hooking up the hoses, blowing out the lines, performing the normal oil change, pulling the distributor, speed cranking the pump, putting the distributor back in, and putting the compressor away. As the kids would say, "that be dumb."
