Old 03-29-2013, 05:05 AM
dirwin's Avatar
dirwin dirwin is offline
Cobra Make, Engine: Factory Five Spec Racer, 5.0 EFI, not donor car built, completed in October 2003, first raced in November 2003
There is really no way, shy of installing an electric valve in the line between the pump and the regulator, to shut off a mechanical pump, and I don't know if that would be feasible.
I built mine originally as a Factory Five Challenge Car, so it I was already set up for fuel injection and it had the in 70 pound electric in-tank pump. I used a fuel inertia switch for safety and just wired the pump to the ignition. When i quit racing the car and went with a 392, 4 barrel setup, I installed a bypass regulator that got my pressure down to a solid 7 pounds, then added a Holley 1-4 pound regulator at the first carb for the Webers.
Sounds like the fuel leaking back into the carbs may be part of the Webers though. I may start another thread about what guys do to stop it.
Again, thanks for the replies, very helpful.
Dave
