Old 03-31-2013, 02:18 AM
Barry_R Barry_R is offline
The red silicone will work. If it matter to you, it will also sometimes squish out into the port and block off some of the port opening you may have worked to optimize. I usually use a Fel-Pro or other reinforced header gasket and add a thin film of the silicone instead of running the big blob.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
