Thread: frightening day
Old 04-02-2013, 03:20 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Hi Jon,
A few things to check are:
Are all the floats levels correct as per IDA procedures?
Were the fuel lines flushed are assembly PRIOR to fitting to the carbs?
Fuel line debris could be preventing a needle and seat from closing correctly.
What fuel pump are you using?
Do you have a fuel pressure regulator?
What pressure do you have it set at?
Gary
