Old 04-02-2013, 06:52 AM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by bobcowan View Post
I completely divorced my oil cooling system from my oil pressure system. There's a couple of -10 ports on my oil pan, and an electric pump bolted to the frame rail. When I'm at the track, I run the electric pump to circulate oil through the cooler. No pressure loss through the engine block, either.
That's a hell of an idea Bob. What pump are you using?
Right now I'm running a Canton tstat and it works fine for where I am, allowing the oil to warm up even in 40 degree weather. Here in south GA, 100+ degree temps are normal in the summer months and the cooler definitely helps even on the street. That being said, getting rid of all that line in the oil system would have to be good for engine oil flow.
