Thread: frightening day
Old 04-02-2013, 11:37 AM
jonalley jonalley is offline
Cobra Make, Engine: FF 302 cam,balanced,48 IDA Webers
Note to self-do not use a heat gun to smooth out the fuzzies on the end of cloth covered fuel lines. Yes, I found dirt.Probably the result of my taking the lines apart to make them look neater. I've only done two of the carbs but there is more stuff in the bottom of the float bowls and at the bottom of the jet seats than I want. Now I need to figure out how to flush out the lines from the pump before I put them back on.
The rear off side shows the most destruction from this event- heater is toast and some relays on the fire wall may be lost but I feel pretty lucky. My problem could have been much worse. Jon
