Thread: FE Torque Curve
  #21 (permalink)
Old 04-03-2013, 11:06 AM
Barry_R Barry_R is offline
My builds, my shop, my guys, my dyno
If it's going to break I want it to happen in my house.
If I can't kill it nobody else should be able to...although I've run into a couple guys that could break a bowling ball in a sandbox...
This is a torque curve...
Still working on it - a bit rich downstairs. But down to small stuff at WOT.
This pull was open loop. I usually try to get the map close enough that the O2 correction percentage numbers are small - then try an open loop pull to verify the work. O2 corrections should be just that - corrections - and not relied on for the tune itself.
Stopped testing 'cuz we were running low on gas - check the fuel psi. Should have waited a few more minutes on water temp to come up 10 degrees more - I let it cool between efforts and I was getting anxious knowing our fuel situation.
The other A/F is on the EFI system computer - so only one side shows here.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
