Old 04-03-2013, 02:01 PM
patrickt patrickt is offline
The info is here on CC somewhere, but IIRC, here are the rough rounded weights of the various alternatives (+/-):
Original cast iron FE block - 200 lbs
Genesis aftermarket FE block - 250 lbs
Pond/Shelby aluminum block - 125 lbs
Aluminum heads, intake, water pump, and flywheel and you're within spittin' distance of the weight of a small block.
