Thread: stack injection
Old 04-04-2013, 09:32 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by wastehauler View Post
I heard that some engines with a radical cam are hard to tune with efi just want the car to be more drivable
Actually, it's just the opposite. The problem with a huge cam is that at low rpm's the vacuum signal is low and erratic. In order for a carb to work well, it needs a good vacuum signal. That's why they have trouble idling, ad why you have to be careful about not putting on a carb that's too big.
EFI really doesn't care much about the vacuum signal. It will provide a solid fuel charge regardless of the vacuum signal or intake port velocity. Even with a huge cam and huge ports, the car can idle well and cruise down the street well without any problems at all.
If you have a radical engine in a street car, EFI will make it real easy to live with.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
