Originally Posted by lippy
Terry, it just links to the general rivnut page. Which particular type do use?
Bob, I think I'm just going to use a bolt, nut, and washer to install if it works well, even if it takes longer.
Lippy,
Depends on the material thickness. If you are going through at least 1/8" material and plan on using a 10-24 thread, I would use a steel rivnut with the ribbs on the side to keep it from spinning, P/N 95105A131. If the material thickness is thinner then I would use P/N 95105A127.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
