Depends on when it was made it may not be accel dfi system
I also had the electronic ignition module die (twice). The ei boxes thave a test light on it. It will tell you if it is getting the fire command from the dfi unit.
With electronic ignition you cannot do the usual ground the coil to see if it sparks. Disconnect a plug wire and have someone turn the car over to see if it sparks to ground. If the ignition box says its getting the fire signal but no spark try the coil. If still none then it's the output stage of the ei box
Check for spark and gas is your right choices. Good luck
Tony
CSX4005LA
