  #21 (permalink)
Old 04-07-2013, 03:38 PM
tcrist tcrist is offline
Lippy,
You are correct. Harder to install. You also do not want to use stainless rivnuts with stainless bolts/screws. Most of the time it causes galling and then you cant remove the screws/bolts. Or if you can, sometimes it damages the threads.
TKB,
Olander is the place where you can get almost anything but they are a bit more expensive.
You can get self clenching hardware from McMaster-Carr also but not as high of minimum purchase.
We buy quite a bit of Pem hardware and quite a bit of other types from many different sources.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
