Old 04-09-2013, 10:22 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Default QA-1 Shock Bump Stops
Has anyone used these QA-1 Bump stops (BC01) that fit over the shock rod?
Bump Stops | QA1 Suspension Components | Circle Track Racing Shock Accessories
You cut them to the desired length to keep from hitting the tires on the fenders. Just wondering how they worked.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
