Old 04-09-2013, 11:59 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by Wbulk View Post
Has anyone used these QA-1 Bump stops (BC01) that fit over the shock rod?
Bump Stops | QA1 Suspension Components | Circle Track Racing Shock Accessories
You cut them to the desired length to keep from hitting the tires on the fenders. Just wondering how they worked.
That style is designed for 7" travel shocks. If you have 4" travel shocks like I do, they are much too tall and soft. Yes, you can cut them, but mine only needed to be a little less than 1" thick.
I used one similar to these that are shorter and much harder durometer, along with delrin shims to get the required height:
QA1 BC02 Bump Stop Bushing - Speedway Motors, America's Oldest Speed Shop
edit: just noticed your link lists the short ones too... they work well.
