Old 04-10-2013, 10:51 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I have looked at several of the replica manufacturers and it looks like most use 10" springs for the front and have no method to limit up travel of the shock other than installing stiff springs. I have read of several brands rubbing the tires on the fenders given the right situation. Of course this varies depending on ride height, wheel back spacing, and spring stiffness. I guess what I am trying to accomplish is to limit the up travel with this device before hitting a fender. I called QA-1 and they claim that is what this is designed for with coil-overs. I have built a droop stop so that is taken care of but I can't see any other resonable up travel limiting device. Perhaps why most manufacturers just put in really stiff springs. I'm just trying to see how they work or are there other options.
This is what I have.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
