Old 04-11-2013, 07:03 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
If you pull the tab on the rotor up, and you put a light dab (NOT a glob) of dielectric grease on the terminals and center ball........"
Not really a good idea. Dielectric grease does not promote the flow of electricity, it impedes it. It should be used on areas like spark plug boots, the plastic or rubber parts of electrical connections, but never directly on wires or metal terminals.
There are many legitimate sources that will tell you the same thing if you do a google search of dielectric grease.
http://en.m.wikipedia.org/wiki/Silic...lectric_grease
http://m.wisegeek.org/what-is-dielectric-grease.htm
Z
'65 K code Mustang
'66 Galaxie 500
