Old 04-11-2013, 04:18 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
The main rason for the dielectric grease is to keep the moisture out. So if you apply it to the spark plug boots, it prevents any moisture under the boot tracking the spark. If you were to coat your finger in grease, I think you would still get zapped with 50.000 volts.
Bit of topic. I'm considering using a crane HI 6 ignition module. Any thoughts on this?
JD
