Old 04-11-2013, 05:27 PM
vatdevil vatdevil is offline
Cobra Make, Engine: Superformance #522
Originally Posted by Jaydee View Post
The main rason for the dielectric grease is to keep the moisture out. So if you apply it to the spark plug boots, it prevents any moisture under the boot tracking the spark. If you were to coat your finger in grease, I think you would still get zapped with 50.000 volts.
Bit of topic. I'm considering using a crane HI 6 ignition module. Any thoughts on this?
JD
Keeps dirt, moisture out and prevents voltage leaks. Good practice to use on all boots.
