Old 04-12-2013, 02:59 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by tcrist View Post
Actually that is not the one if Jim's has the three screws holding them in. The one that FWB posted looks to be held in by an o-ring, not screws.
Also, the one that Bugman has probably is not the same either if it has a single "grub" screw.
They might be able to be modified, but you will have to have all four for it to look right.
Terry, the three set screws are threaded into the wheel around the hub they protrude into the center and catch the groove in the spinner so they don't accidentally fly off.....some are like mine and there are others that have three sockethead cap screws on the face that thread into the wheel. into the holes shown on the face of the hub
the aluminum casting foundry here can sand cast these from a sample, i would do this if i knew i could actually sell them, the little bit of machining on the back side is a simple lathe operation.....i would have to make at least 50 to keep the foundry happy on pricing
Fred B
