  #34 (permalink)
Old 04-15-2013, 07:10 PM
COACH MIKE COACH MIKE is offline
Club Cobra Member
Cobra Make, Engine: Hurricane Cobra - Keith Craft 428 stoker, 600 HP/614 Trq
Send a message via AIM to COACH MIKE Send a message via Yahoo to COACH MIKE
Default msd
This is typical of the MSD small dist. cap. You can get a "cap adapt", I believe it is part #8445. This will supply you with a cap extension, new larger cap and larger rotor. The new parts will space you contacts farther apart and, for the most part, stop the deposit build up and cross firing in the dist. cap. Hope this helps. In the summit catalog they will tell you there is no cap adapt for your dist, however, I did the research and have this same dist and same cap adapt on my Keith Craft 482. Hope this helps.
