Thread: running rich
Old 04-17-2013, 09:07 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by MOTORHEAD View Post
".............. Carbs had blocked pump valves when I got them , but were replaced with .50's. I think I'll try advancing the initial timing first. Zrayr: just read the info you showed, very interesting.
I'll report results as soon as I have some!
Did you run it at all with the 00 acc. pump bypass valves ? I have 60's now and am thinking about doing some experimenting in that area.
My 10 & 14 degree bushings are on the way. We'll see if I have any benefit. Right now the car seems to like 22 initial timing best as far as idle quality goes. A lot of my off idle stumble went away with going to the lightest dist. springs, but sometimes the idle will hunt a bit with them. It just starts advancing too soon, so I'm trying the next lightest combo.
".............When I mentioned A/F meter to Inglese he said " do you want it to run right, or do you want to chase numbers?"
I want both, as much as possible. I realize there exceptions and trade-offs.
Ha ha, he's said much the same thing to me. He's right about one thing, you can get the best performance out of a set of Webers when they "appear" by the numbers to be running a bit rich (especially on the low end). Just my experience so far.
Z.
'65 K code Mustang
'66 Galaxie 500
