Old 04-20-2013, 09:24 AM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Hey Todd,
1.) Even though you see some weights you may have lost others. I would rebalance the front tires. Tire pressures around 28#. If you do remove the wheels, make sure they line up with the 5 lug recesses on the back of the wheel hub when going back on over the lugs for the hub assembly. Also verify that these are lined up now, since people can put them on wrong and induce this shake.
2.) High Temp Dot 4 in the brakes and clutch. Owners Manual is not up to date and a generic build. BTW your engine will prefer 10w30 oil.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
