  #29 (permalink)
Old 04-22-2013, 07:14 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Luce, you got me thinking about that and I forgot there is a down measurement to. It's explained in this Ford Racing tech sheet, page 7 (Alternative Method). The dist. measurement method I have found does not seem to always work as I have measured dist. that do not match but when measured under the alternative do check out. Regardless, I looked and saw you have a 351 based engine so the dist. lenght may not be the same. Ford says the alternative method can only be checked without the cam in the block. After I found this again I looked for one specific to the 351 based engine and could not find one. I believe the .005 up and dowm check should apply. Sorry for not being complete on that.
http://www.fordracingparts.com/downl...-6007-X302.pdf
ADDED: I finally was able to find a sheet specific to the 351. It looks like it's pretty much the same.
http://www.fordracingparts.com/downl...427AFT_ART.pdf
I
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
